Helendor a no-KYC/AML crypto exchange
Citaat van Helendor op 29 november 2026, 15:57Helendor – a no-KYC/AML crypto exchange where privacy is built into the very architecture of the service. No passport required, incoming coins aren’t run through a scanner, and funds don’t sit around. Logs and IPs aren’t retained on servers, transaction data isn’t accumulated, and no customer database is kept. Every exchange is a separate one-time order with an isolated wallet and a PGP signature. The incoming and outgoing transactions aren’t linked to each other on-chain. What the user gets on the way out is clean crypto sourced from the liquidity of major exchanges.
Why users choose an exchange with no strings attached
A major exchange asks for verification. For large volumes that’s justified; for an individual it’s just another hurdle. Coins bought on P2P a few years back or received as a transfer from an acquaintance carry a history with them. When you deposit them to an exchange, that history can draw the attention of the compliance team: a freeze, a request to prove the source of funds, an account lock. That’s exactly where the demand for crypto exchange with any AML and no KYC checks comes from. The logic is simple: if the service doesn’t ask for documents and doesn’t scrutinize the incoming transaction, the risk of a block disappears. The user gets an asset they can then do whatever they want with. That’s how an anonymous exchange with no KYC or AML checks works — no forms, no identity confirmation, no questions about where the coins came from. It’s also worth understanding the difference between the levels of checks. KYC is identity verification: passport, selfie, address. AML is analysis of a transaction for ties to risky sources. A crypto exchange with no KYC and no AML does neither. Hence the result: an anonymous crypto exchange with no KYC or AML is available to those who aren’t willing to hand over documents just to convert. No documents, no coin scanning, no archive of customer data — that’s how Helendor works from the inside. The key question when exchanging crypto with any AML and no KYC checks is where the coins on the way out come from. If a service just forwards what it received, there’s no break: the blockchain is transparent, the chain can be traced. The working model is built differently. The incoming transaction goes into a pool, and the outgoing one is assembled from reserves that have nothing to do with the deposit. That’s what conversion without KYC and AML really is — the incoming and outgoing flows aren’t linked on the blockchain. What you get on the way out are coins with a clean history, from the reserves of major exchanges where the assets have already gone through their own compliance. That’s why an exchange that doesn’t block for AML can accept coins with a high risk score. The transaction isn’t laundered — it’s isolated. That’s what “no blocks” means in the technical sense. A service like this, with no KYC and no AML checks, behaves predictably: the result doesn’t depend on the history of the incoming asset. An anonymous crypto exchange with no KYC or AML checks rests on one principle: input and output are separated, and the link between them can’t be reconstructed.Three steps to a finished result
Step one. Choose the direction. Say you need to anonymously exchange Bitcoin BTC for Tether USDT with no KYC or AML. You enter the amount, the rate is shown — floating or fixed.
Step two. Get the payment details. The service provides a wallet address for the incoming coin. A no-custody exchange means the asset doesn’t stay on the balance any longer than it takes to process the operation.
Step three. The exchange is processed.The questions that come up most often
Red AML after P2P. USDT bought on P2P, the seller turned out to be tied to a mixer, the coins are flagged. Where do you offload dirty crypto? The exchange route is closed. A crypto exchange with no KYC checks is the way out: the service accepts the asset, and the user gets clean USDT or BTC. This is a standard route for anyone who’s run into a flag for the first time.
Privacy by default. Your main wallet shouldn’t intersect with your operations. An anonymous exchange with no KYC or AML solves that: identity isn’t tied to the transaction, and there’s no customer database. This is the baseline scenario for people who value privacy. You can exchange crypto anonymously with no registration and no extra steps. A crypto exchange with no KYC or AML checks also covers an adjacent need: you don’t have to explain where your funds came from.
Network-level privacy. For those who care not just about the blockchain but about their IP, an onion exchange and exchanging over Tor come in handy. It’s not a marketing gimmick — it’s a way to avoid showing your network address to the service. Anonymous crypto exchanges with that option are rarer, but demand for them is steady. A hidden exchange strips away one more layer of metadata.What to keep an eye on
Rate: A floating rate follows market swings at the moment of processing. A fixed rate is locked in when the order is created. The second is more predictable; the first is sometimes more profitable. For planning an operation, fixed is more convenient: you know the final amount in advance.
Registration: An instant crypto exchange with no registration means no account, no email confirmation, no repeated captcha. You picked a pair, entered a wallet, sent the funds. No passport needed here isn’t the exception — it’s the norm.
A classic atomic swap is a cross-chain exchange with no intermediary, where both sides lock funds in a smart contract. When applied to exchanges, the term is used more loosely to mean the absence of an intermediary in the process. If you see “atomic swaps without KYC” mentioned, check what exactly is meant. Most often it’s a service model with broken links, not a pure hash-timelock contract. For the user there’s almost no practical difference: the result is the same — a crypto exchange with no KYC or AML and a clean output. A crypto exchange with no verification works on the same logic in that sense: what matters isn’t the name of the technology but the fact that identity and history aren’t tied together.Supported assets
The list is broad, and that matters: many exchanges with no AML/KYC verification work with a narrow set of coins. A crypto exchange with no KYC or AML covering this much is rare.Major ones:
Bitcoin (BTC), Monero (XMR), BNB (BNB), Ethereum (ETH), Wrapped Bitcoin (WBTC), Optimism (OP), Theta Fuel (TFUEL), Kaia (KAIA), Avalanche (AVAX), Harmony (ONE), Celo (CELO), Arbitrum (ARB), Metis (METIS), Moonriver (MOVR), Cronos (CRO), Polygon (POL), Ronin (RON), Chainlink (LINK), Worldcoin (WLD), PAX Gold (PAXG), ZKsync (ZK), Ethena (ENA), Uniswap (UNI), 0x (ZRX), Aster (ASTER), Mantle (MNT), Pepe (PEPE), Shiba Inu (SHIB), Sonic (S), GRAM (TON), Solana (SOL), Algorand (ALGO), Tron (TRX), Bitcoin TRC20 (BTCT), NEAR Protocol (NEAR), Tezos (XTZ), Aptos (APT), Kava (KAVA), Polkadot (DOT), Icon (ICX), Injective (INJ), Filecoin (FIL), Ontology (ONG), Zcash (ZEC), Cardano (ADA), Dogecoin (DOGE), Litecoin (LTC), Bitcoin Cash (BCH), Ripple (XRP), Dash (DASH), Ethereum Classic (ETC), Kusama (KSM), Qtum (QTUM), Cosmos (ATOM), ThunderCore (TT), Neutron (NTRN), Waves (WAVES), Stellar (XLM), VeChain (VET), Zilliqa (ZIL), Ravencoin (RVN), DigiByte (DGB), Akash (AKT), THORChain (RUNE), Sei (SEI), Osmosis (OSMO), Sui (SUI).Stablecoins:
Tether USDT on ERC20, SOL, AVAX, ARB, CELO, POL, TRC20, BEP20, TON, DOT, XTZ, NEAR, KAVA, KAIA, APT, ALGO, OP, MNT.
TrueUSD TUSD on ERC20, BEP20, TRC20, AVAX, POL, ARB, OP.
USDD on BEP20, TRC20, ERC20.
USDS on AVAX, BEP20, TON, SOL, ERC20, POL, ARB, OP, KAIA, NEAR.
USDP on ERC20, SOL.
USDC on AVAX, ERC20, SOL, BEP20, POL, OP, CELO, MNT, ARB, APT, ALGO, NEAR, DOT, KAVA.
USDE on ERC20, BEP20, OP, ARB, KAVA, MNT, AVAX, TON.The list of pairs covers the main scenarios users come with.
An anonymous Litecoin LTC to Tether USDT exchange with no KYC or AML is in demand among those who hold LTC and want to move it into a stablecoin without unnecessary questions.
An anonymous Ethereum ETH to Tether USDT exchange with no KYC or AML does the same job for the mainnet.
An anonymous Monero XMR to Tether USDT exchange with no KYC or AML is chosen by those who’ve worked with privacy coins and now want to move into a stablecoin without revealing their history.
An anonymous Bitcoin BTC to Tether USDT exchange with no KYC or AML is available within the general limits, with no separate rules and no extra conditions.
Anonymously exchanging Tether USDT for Monero XMR with no KYC or AML is popular among those who want to swap a stablecoin for a privacy coin.
Anonymously exchanging Bitcoin BTC for Monero XMR with no KYC or AML is in demand among those who need to swap BTC for a privacy coin anonymously.FAQ
Do I need verification? No. This is an exchange with no passport selfie and no address confirmation — identity is never established.
What about coins with a high AML risk? They’re accepted. The incoming transaction isn’t checked for risk score and isn’t grounds for a freeze. That’s exactly what a crypto exchange with no AML is: the status of the incoming asset doesn’t affect the payout decision.
What coins come out? Clean ones, from exchange reserves, with no blockchain link to the deposit. That’s the difference from a plain converter. A crypto exchange with no verification pays out clean assets specifically.
How does the process work? Choose the direction, enter a wallet, send the funds, receive the credit. A no-KYC crypto exchange adds nothing extra to that.
Can I exchange bitcoins without a passport? Yes, on the same terms as any other coin on the list.
How do I anonymously exchange crypto with no KYC or AML? Choose the direction, enter a wallet, send the funds. That’s the whole instruction.Website: https://helendor.org/en/
TOR browser address:
http://23ce7dmy44tksnls4nx4vqxxtvlmkbihqzrlmyfgsfucluihpg4r6lid.onion/en/A crypto exchange with no AML or KYC verification handles a specific job: converting an asset without tying it to an identity and without the risk of a block — that’s control over your own financial information, not circumventing the law. Some people need it for working with private assets, some to avoid losing funds because of someone else’s mistake in the chain, some for peace of mind. An exchange with no verification and no AML is the standard, not the exception — it remains a working tool for those who value privacy. A no-KYC/AML crypto exchange removes an extra layer of risk the user never created.
Supported assets
Major ones:
Stablecoins:
USDP on ERC20, SOL.
FAQ
Een thuisbatterij levert in de winter weinig op omdat de panelen weinig opwekken. Het stuk legt uit wat hij wel doet en wat dat betekent voor je pelletkachel en stroomuitval.
Hoe je een echte pelletkachel aanbieding herkent: vergelijk adviesprijs, check garantie en onderdelen, reken rookkanaal en pellets mee en let op tegenstrijdige informatie over subsidie en geveldoorvoer.
Een showmodel is pas een goede deal als de korting boven de gewone 20% uitkomt en de garantie en onderdelen geregeld zijn. Reken ook rookkanaal, plaatsing en pellets mee.
